Poratl2 page login
Hi Gurus,
I have question like below
I have menu like attached document.
  1. List item
Now after sign-up a user id is created with specific role in flow studio.
Next time user log into portal it needs to go always via standard Novacura portal?
Also I want to show them a default page after login . But as per screenshot after log in he sees only menus and after selecting options from menu can go to poage.
How to land him in a default page once he logs into.
Bhaskar
Hi, all pages are full URLs, that can be linked to.
Thanks for this. I tried this before and somehow not workinga nd now it’s ok.
I have below questions
Can I skip the below default loging of Novacura as clients want to go directly to a page when a page link is provided in a workflow
Also as per teh above attachment I created multi menus but once client log into via default login page how to show a default page which I ahve created for them . If you see my previous attachment , client is seeing only menus after log in not a page.
Basically after loging I want to show a default page.
Thanks in advance.
Hi All,
Any help for the above .
It sounds like you are linking to the web client, not the portal page’s URL?
Try adding ‘&autologin=true’ or ‘ ?autologin=true’ at the end of the URL.
I’m linking Portal2 page.
Hi Daniel,
For poratl2 loging '&autologin=true’ or ‘ ?autologin=true’ doesnt allow to loginto a page.
Is there any way that I can call a mchine WF by taking user id input and validate this.
Is there any alternate way apart from OPEN ID ?
Br,
Bhaski
A dirty trick I think you have already received is to use powershell to open a url and auto enter username and password. Not recommended for obvious reasons, but it could look something like:
