Kanban Destination Status map in User Workflow
I’m facing a challenge in Kanban portlet like below.
Let’s say I’ve 3 status in KANBAN portlet.
stat1 ,stat2, stat3
In data source in KANBAN I user STATUS column which gives the status of each COLUMN.
Then created a DRAG & DROP WF for KANBAN and took teh above STATUS column.
I tried to creat rule in WF where I can go stat2 from stat1 but not to stat3.
Though I used STATUS column in I/P table it’s always showing the source status not destination status.
if i drag from stat1 to stat3 it is supposed to show status column as status3 but showing status1.
How to achieve this because in portlet it shows COLUMN status but WF shows source stats.
Need your sincere help in this.
Bhaskar
I did it using operation Schema
