Portal 2 - Selecting workflows
Hello!
I have some questions regarding data sources and quick actions. When I create a new flow from a Record portal and then try to select it as a data source, it doesn’t appear as an option. Are there any requirements for it to be selectable?
Regarding quick actions, it’s the same issue. I have created 2 test flows and tried to select them, but none appear in the menu. I can see all other flows more or less, but not the ones I want.
Best regards
Viktor
Hi Victor,
Hope these two links will help you.
Common configuration | Flow Help
Table | Flow Help
Hi Viktor,
Had to test this myself in an internal environment. For a machine workflow to be visible and used as a datasource you need to create the machine workflow with a “datasource” Input and variable schema as shown in the screenshot. But when you create a workflow from the portal, this is done for you. My workflows that I create from the portal shows up as datasources in the Portal dropdown.
These requirements isn’t very clear in the Flow help. Should be improved @Amri .
For quick actions in the table portlet, any machine workflow seam to show up, regardless of the input schema.
Thanks Albin I’ll check on improving the flow help requirements.
Hi Albin,
Thanks for the information. I agree that the flow help should mention this as well
BR
Viktor
