I have a very simple workflow;
basically just taking 3 fields through user input (2 text fields and 1 drop down selection)
this workflow is then connected to a machine workflow.
First bug I’m encountering is the drop down selection list, (I’m getting it from the table before the User Input step) all the text is white colored so it’s not visible to the user in the webclient or through debugging. But if I select something, the value reflects in the variable. It’s just a visual issue.
you can see here the text is not showing:
2nd issue is this:
Each time I run the workflow, it tells me unable to resolve variable X, Y, etc.
These variables are assigned in the beginning of the workflow and later linked to the connected workflow after the end step.
update: fixed the 2nd issue, just made different variable names for the mapping. not exactly the same.
Any help would be great, thanks :)!
