How to get variables set by a listner in the workflow
I have 2 tables portlets; Table B have a listner “on row selection” from Table A
When I select a row in Table A, Table B only show data with Code={Code} where {Code} is given by the Code column in the selected row in Table A.
This works well if DataSource in table B is Database.
However, if DataSource is Workflow, I can’t get the variable {Code} in the workflow
This seems a very basic function, but I couldn’t find any documentation how to do it.
Can you help me?
You can try this if you add this structure to your datasource workflow:
Then you can check in an assignment step if the Input table is empty or has any records:
And in the query you can use that variable:
I hope this helps. :slight_smile:
It worked :slight_smile:
Many thanks
Just a small note, the where clausula only worked doing something like
Where [Order_No] = ‘{rec__Order_No}’
