I want to select from a table in a machine step but I want to pass the table name as a variable to the select statement (see attached image). The assignment variable name is tab_no
The tab_no variable will change each time the flow is used so I cannot hardcode the table name into the flow.
I am getting an “expected token” error. Can anyone help?
Thank you for your reply. I actually just put in a separate step with Flowscript in it that takes what is being entered into the table and writes it to a Flowscript table. Then I loop through that table to display it.
