Fetch 2 different tables into one "menu selection"
I am wondering how two different tables with different menu options can be combined and used in a “Menu selection” menu. The desired outcome is that if a specific condition is met, the options from one table should be displayed, and if another condition applies, the options from the other table should be shown.
I would be grateful for any help I can get.
Best regards,
Viktor
Example.
You could just have one table and then add a column to it, let’s call it “Type” or something. Then based on previous conditions you can then filter the table (in assignment/script step) before using it in the User Step . Like this:
Thank you, that helped a lot.
BR, Viktor
Great! Let us know if you have any other questions. Happy Flowing! :slight_smile:
Hi again!
I would like to set the default value in my menu selection input to orderId number 8 when running the flow, instead of the first value in the list. How can I retrieve this specific value from the list?
Hi again :).
Many of the user steps items can have a default value. Apart from sorting the list you can also provide a default value for list selections, like this:
Hi Alluse,
Sorry for replying on this thread but might be related so I tried.
I wanted to use List Selection Input but the table comes from SQL.
How can i add an “NA” option in my table to display in the field?
I hope I am clear on this.
Hoping for a response soon!
Faye
You can do it one of two ways:
  1. Add a union to your sql query with a bunch of empty column names except the one you are displaying in the Input selection
  2. Append a record to your existing query using flowscript
thank you daniel that was really helpful!
