Filter List Selection based upon another List Selection
I have two List selection controls on a screen, one is “Region” and the other is County". When a region is selected from the region List selection I want to only display Counties in the Counties List selection that are in the region that is selected. See attached pic. is this possible?
I am not using the latest version of Flow Studio (6.4). I am on an earlier version.
We accomplish this with a two column data grid (both value lists) where the second column’s table expression includes a where clause which is based on the first column’s value.
I don’t know if there is another way to do it in flow without a datagrid.
Thanks for the reply but I don’t want to use a data grid, it has to be two List controls.
Within the same user step this is not possible,
Yes that is what I feared, thank you.
as mentioned,we cant connect 2 lists in the same element.
As a workaround we sometimes place a refresh button.
Then after refresh we loop back and filter available options in list 2 based on selection in list 1.
Here is an example:
Also example flow here:
https://novacura-my.sharepoint.com/:u:/p/ivan_stojiljkovic/EZIoe3WiHdVOo1HkaK9WLpABbRdAE54R7OYh3hVMQ6CZng?e=djdPCO
Hi Ivan,
The above URL isn’t working.
Can you please provide teh URL again.
Bhaskar
