I want to loop through two records in Flowscript and when one value is not found in one recordset I want to add it to another record and out put it. The two records I want to loop through are the output variables from a grid control;
One is called _dsMap2 and the other is called _dsMap
I have an outer loop that loops through _dsMap and an inner loop that loops through _dsMap2.
The two records have the same name values in the output; a field called “LI_NO”. They different values for tht in each record. I want to find the “LI_NO” that is in one but not in the other…
Then I want to output that to a declared record variable (with one field; “LI_NO”). It must be a record, not a table.
My code is below, it isn’t correct but I think I am on the right track
Can anyone help?
LET _missingParts=[LI_NO];
FOR _dsMap_rec IN _dsMap DO
FOR _dsMap_rec2 IN _dsMap2 DO
if _dsMap_rec2.LINE_NO!= _dsMap_rec.LINE_NO then
LET _missingParts = [LI_NO=_dsMap_rec.LINE_NO];
END
DONE
done
RETURN _missingParts;
