Bhaski
                    July 10, 2024, 11:33am
              1
              Hi Gurus,
I was trying below script test to do a calculation and not able to do , need your help.
I have a flow table WHINVTBL which below data
PArtID
PartDesc
InvQty
Intransit
123
itm1
10
2
456
itm2
6
1
 Now calculating SOH by doing InvQty - Intransit and want to return a new table from script with below value
PArtID
PartDesc
SOH
123
itm1
8
456
itm2
5
 ------- using below -----------
let SOH =0;
let  NEWWHINVTBL = WHINVTBL ;
FOR k in WhINVTBL {
set SOH = k.InvQty - k.Intransit;
NEWWHINVTBL =NEWWHINVTBL & [ITMID: k.PartId ,ITEMDESC: k.PartDesc, SOH: SOH];
return NEWWHINVTBL;
It’s not happening, please help me in this what wrong I’m doing in script.
                rovech
                    July 10, 2024,  2:00pm
              2
              Hi, I think you should use the Empty statement to initialize the NEWWHIINVTBL.
Even easier is probably to use MAP AS:
/Roel
                ivstde
                    July 11, 2024,  1:06pm
              3
above you are saying let NEWWHINVTBL = WHINVTBL ; which means that the columns of NEWWHINVTBL should be the same 4 columns as WHINVTBL too. (PArtID, PartDesc, InvQty, Intransit)
But then in the loop you want to add record with 3 columns (ITMID, ITEMDESC, SOH) to NEWWHINVTBL which is defined as 4 column table.
So just define
let NEWWHINVTBL = table(ITMID, ITEMDESC, SOH);
and it should work.
                Bhaski
                    July 16, 2024, 12:31pm
              4
              Thanks Ivan,
It helps me as I did a small mistake there.
                daniel
                    July 16, 2024,  9:34pm
              5
              Also, for performance reasons, I would NOT do “for k in WhINVTBL”. Instead try:
let SOH = 0;
let NEWWHINVTBL = map WHINVTBL as [ITMID: PartID, ITEMDESC: PartDesc, SOH: InvQty - Intransit];
return NEWWHINVTBL;
