Unable to Transform Data
Hello,
I am trying to use a model transformer to transform my input - bcl:System.Collections.Generic.List<System.Collections.Generic.List<System.String>> - into a more desired form - a table. In testing, I can compile my transformation code versions, but I get the below error in my flow. I have tried making a base case by manually setting an output value to a random string (not using my input data), but this results in the same error. Despite this test, I suspect it is due to the custom specification of my input data and backend JSON deserializing. To combat this, I got this custom output in flow, copied it as JSON then imported it as a model so I did not need any custom specifications. However, this generated model would not work with the data resulting in more errors. More specifically I believe the issue may be that my JSON input only contains values and is not the general format of{“name”:“value”}. However, I cannot seem to transform my data into this format, and I cannot change the input. Below is an example of the JSON of my input data. I have replaced the values with other values. Any help/insight would be greatly appreciated.
Best,
Andrew
TransformFailed
“text”: [
“value”: {
“value”: [
“value”: “column_name_1”
“value”: “column_name_2”
“value”: “column_name_3”
“value”: “column_name_4”
“value”: “column_name_5”
“value”: “column_name_6”
“value”: “column_name_7”
“value”: “column_name_8”
“value”: “column_name_9”
“value”: “column_name_10”
“value”: “column_name_11”
“value”: “column_name_12”
“value”: “column_name_13”
“value”: “column_name_14”
“value”: “column_name_15”
“value”: “column_name_16”
“value”: “column_name_17”
“value”: “column_name_18”
“value”: {
“value”: [
“value”: “hello world”
“value”: "hello world "
“value”: “12345”
“value”: “12345”
“value”: "12345 "
“value”: “12345”
“value”: “12345”
“value”: “12345”
“value”: “12345”
“value”: “12345”
“value”: “12345”
“value”: “12345”
“value”: “12345”
“value”: “12345”
“value”: “”
“value”: {
“value”: [
“value”: “12345”
“value”: “12345”
“value”: "12345 "
“value”: “12345”
“value”: “12345”
“value”: “12345”
“value”: “12345”
“value”: “12345”
“value”: “12345”
“value”: “12345”
“value”: “12345”
“value”: “12345”
“value”: “”
Hi again,
Instead of a model transformation, you could try to take the JSON above and create a model from it, then in the “usedResponseRange” model you use that new “text model” for the “text” column of type Object.
Hope this helps! (and that i am understanding the post correctly :slight_smile: )
Hello,
This is what I had tried previously but could not get to work. I end up getting an error like below when taking my output as a JSON and making it a model.
hello Andrew,
seems to be you are having larger data set therefore you have to split it in order to get it successfully.
private Model_GetPodDetails_OK_binary_ Image_to_binary(Model_GetPodDetails_OK input)
            var output = new Model_GetPodDetails_OK_binary_();
            //Transformation code start
            **output.data = new Model_GetPodDetails_OK_binary_.Embedded.data();**
            output.data.orderReferenceNumber = input.data.orderReferenceNumber;
            output.data.signatoryName = input.data.signatoryName;
            output.data.signatureTime = input.data.signatureTime;
            output.data.signatureImage = new System.IO.MemoryStream(Convert.FromBase64String(input.data.signatureImage.Split(',')[1]));
            //Transformation code end
            return output;
BR
Shyaminda
Hello,
This makes sense. Thanks.
Best,
Andrew
