Bhaski
January 13, 2026, 7:17am
1
Hi Gurus,
I need ahelp in flow script while calling an integration.
in an integration I’m getting below data
let InvestorTBL =
isEstablishment: “NO”,
designation: [
nameAr: “aa”,
nameEn: “aa”,
code: “aa”
registrationDate: “aa”,
person: [
idNumber: 11,
passport: [
number: “11”,
issueCountry: [
nameAr: “aa”,
nameEn: “aa”,
code: “11”
issueDate: “11”
dateOfBirth: “11”,
nameAr: “aa”,
nameEn: “aa”,
gender: “MALE”,
nationality: [
nameAr: “aa”,
nameEn: “aa”,
code: “11”
isEstablishment: “YES”,
designation: [
nameAr: “bb”,
nameEn: “bb”,
code: “bb”
registrationDate: “bb”,
person: “Nil”
return InvestorTBL;
Now if you see sometimes for soem data person: “Nil” , how to handle the op in ky scripyt to skip this Nil record.
Thanks in advance !!!
REST API call
Br,
Bhaski
Hi, in that example you have different columns for the two rows so the syntax seem a bit wrong.
But assuming you have the same values you should be able to return the table with: where person != “nil”
JonasG
January 15, 2026, 12:52pm
3
You get this data from a REST API call I assume, are you using the REST connector? If so, how did you set up your model for receiving data? Normally the connector should be able to skip objects with no content, but I’m not sure what happens if the property is set to “Nil”. Maybe you could use a Model transformation to change the data from “Nil” to an empty “person” object.
Bhaski
January 15, 2026, 1:14pm
4
Thanks for the reply.
I have tried in script to do something person != “nil” , it’s not capturing
Bhaski
January 15, 2026, 1:16pm
5
Hi Jonas,
It would be grtae if you can provide me an example for this.
