"Select Distinct" not working in Studio version
I have a FlowScript code segment that works in our DEV Environment but doesn’t work in PROD. I think it is because the DEV version of Flow Studio is 6.14.13.8 and the PROD version of Flow Studio is 6.13.17.40064.
Is there a Workaround I can use?
The code is
let x = select distinct ln4, prt, loc from dupcnt6;
return x;
“Distinct” is not recognised in the version 13 (I think). I removed “Distinct” and tried “GroupBy”, it doesn’t work.
this is how we used to do it back in them olden days… versions :slight_smile:
let x = empty(dupcnt6);
for item in dupcnt6{
if count(x where ln4&prt&loc = item.ln4&item.prt&item.loc) = 0 : set x = x & item;
return x;
That worked, thank you very much!
