Progress Bar in Visual portlet
Hi Gurus,
I need a small help.
I have designed a registartion process where let’s say a prospect needs to fill up 6 tab having 5 fields each.
Behind each TAB , I have a table to store data.
Now I want to create a progress bar where if all fields are filled up it will show a prgress
eg. upto 2 TAB all fields are filled up, It will show 40%
Any help appreciated.
Br,
Bhaski
Hi, Sounds like a bar chart? Or HTML portlet if you want to go a little bit outside of the box, but its also more complicated.
Thanks for the reply.
Not a Bar chart but I think there should be one Progress Bar portlet which can show prgress of option like registration,if a prgress has 5 steps and I’m doen with 3 , show prgress.
I have done it using HTML code an dthanks for your hints.
Bhaski
