Novacura Flow Server Upgrade
I’m trying to upgrade flow but I am getting this error
“section or group name is already defined”
Any idea on how i can fix it?
thank you,
alyazia
Could you provide the web.config file? In theory, you should make a backup of your Novacura install folder, then manually edit the web.config file to remove the line(s) it is erroring on, then attempt to perform the upgrade again.
this is where its throwing the error;
I just tried an update to the same verion on my local Flow and that went ok. Perhaps best Alyazia if you raise a ticket in our Jira and our support can take a look at it.
The error obviously sounds Oracly so not sure if it has something to do with the connector or that a PL SQL tool prehaps is installed on the flow server? Wild guessing
