Novacura Connector export/import not working
Have you noticed that in flow classic export and import of rest connectors does not work.I am not sure if this is fixed in flow connect. RnD has refused to support on this ticket which I have created.
This is very inconvenient situation for the customer. You will setup a connector in the test and in some cases you forget the setup thinking its just export and import but suddenly Novacura doesn’t support the feature. Setting this up again is very time consuming.
What exactly is not working? I know when we did REST connectors export and import there was additional exports that had to happen after open the REST connector project within the settings and we were able to export an ncrp (something like that) file type.
Hi @wpuymac I have export and imported the rest connector, Only the name was imported not any models or operations. I raised a ticket and below was the reply
Are you sure that you exported everything
And during import, replaced it and imported everything? (As a good practice you could also first export everything from the importing environment just in case)
export / import of REST in classic was always a bit…weird :slight_smile:
It was always a 2 step process:
  • export / import “header” of the REST connector
  • export / import “contents” of the REST connector
Never had issues (when i remembered to do both steps :slight_smile: )
Btw, Which flow version are you on?
