I found an old flow which might have been useful about cycle counting, but when I try to import it I get the following error “invalid file format, version 5.10x and later is supported”
is there anyway by changing the XML for example to get it to be 6.14 compliant ?
Paul
i had to open a couple of flows from V5 that were giving me an error and what worked for me is installing a local 6.12 instance (on my local machine, from offline packages), then importing V5 flows there and then exporting those and opening in an actual Flow server.
