Duplicate "Next" buttons appearing in User Interaction steps – Novacura Flow
Hi everyone,
I’m currently working with Novacura Flow Connect and I’ve run into a UI issue in some of my User Interaction steps.
On specific screens, the “Next” button is appearing twice. This doesn’t happen on all screens, only on a few, and it’s causing confusion for the end-users.
I have checked the following:
  • The workflow logic for those specific steps.
  • The configuration of the User Interaction node.
My questions are:
  1. What could be causing this duplication in the Flow Connect client?
  2. Is there a specific setting in the “User Interaction” properties or the “Machine Workflow” that I should check to fix this?
Any guidance or troubleshooting tips would be greatly appreciated!
Thanks in advance.
Are you working with the Web Designer?
I’ve experienced this a few times, especially with earlier BETA versions of the Web Designer and especially in apps that was created in the Legacy designer and then moved to the Web Designer.
For some reason user steps exits duplicate. Just recreating the exits of a User Steps fixed the issues for me.
