Connecting to IFS when Novacura User is different from IFS User
I have been trying the above where the IFS10 connector doesn’t use a global user id. It works if I login to novacura by entering the Username and password manually. I get the prompt to login to IFS user, and the Workflows that use this connector will work without errros.
However, if I was to try and use the Sign in with your Microsoft domain account, then the user will be signed in, if I am logged into windows with the same account, but I do not get a prompt to login to the IFS user. It just signs the user in using SSO.
But afterwards, when running the workflow, I am getting an error.
So seems the above only works if user manually logs in. Is this your same experience? Or am I missing something?
