I want to pass the json value to a label
like this.
“OurSeverity”: “UNQUALIFIED”
Try the JSON module JSON module | Flow Help
Thanks for the information Ola, May be I will re phrase my requirement directly, so you can provide the correct answer
I want to patch the ourdescription in case window
1st I need to fetch the current value and then enter the value in novacura and then patch it. But I need to send the value with previous blank spaces and lines.
