Translation of TAB in PORTAL2
Hi All,
I’ve onserved a wiered thing during portal2 a TAB translation.
When I do translation (english to Arabic) for any TAB in my solution from translation page it doesn’t reflect.
Wheras if I directly put english or Arabic in any TAB in my solution, it reflects.
Request you to help me in this because , I guess any item (navigation,container,protlet etc.) I choose to translate from eng to arbic via trnaslation page it should work there.
Please help me in this.
Bhaskar
@Bhaski If you want to translate, you should do it through Flow Studio, and add Arabic as one of the languages. Then, for user profile, select the Arabic language. Next time you log into Portal2, Arabic will be displayed.
If this isn’t possible to do, you could try a different browser plug-in and see if that works better than the one you are currently using. Maybe something like this one:
Good luck :slightly_smiling_face:
Hi Daniel,
Thanks for the reply.
Let me explain this more perhaps I couldn’t phrase it properly.
In an a screen in a portlet container I’ve multiple portlets .What I’m seeing now during translation –
Apart from portlet name translation I can translate everything.My client is doing Arabic translation where Navigation,item fileds inside portlet,portlet container,button name everthing I can translate where user with eng,ar language can see respective data in own language but I can’t translate portlet name through translation page.
Why it’s like this?
Bhaski
