Run a schedular for a date and time
Hi All,
Need a help for the subject topic.
How I can schedule a machine workflow to a particular date and time?
Bhaskar
Just right-click the workflow and choose scheude, and set when you want it to run
Thnaks for the reply.
I used this option but how to schedule for machine workflow run for a particular day and time which I can fetch from a databse column.
Bhaskar
Then you would have to have a higher frequency on the scheduled flow, and then as a first step check against your table if it should continue to run or quit, and keep that more advanced logic there.
I Connect you can use what is called Cron expressions, letting you do a lot more complext stuff. But in classic, I think the method above is the way to go. I have done that at times to not email things on weekends or days off for example.
