I am trying to upload a document to a REST endpoint using flowscript. The call requires me to use multipart/form-data. The documentation on this is sparce and I cannot get a straightforward answer.
I am attempting to do Retrieval Augmented Generation (RAG) on a document. The curl call is:
curl -X POST -H "Authorization: Bearer YOUR_API_KEY" -H "Accept: application/json" \
-F "file=@/path/to/your/file" http://localhost:3000/api/v1/files/
When I run in Connect, I get this error:
HTTP Code: 400
Error: Bad Request
Message: The Content-Disposition header field "name" must be provided.
My code:
let url = `/api/v1/files/`;
type ErrorType1 = {
detail: {
type: text,
loc: text*,
msg: text,
input: null
type ErrorType = {
detail: text
type ResponseType = {
"id": text,
"user_id": text,
"hash": text?,
"filename": text,
"data": {
"status": text
"meta": {
"name": text,
"content_type": text,
"size": number
"created_at": number,
"updated_at": number,
"status": boolean,
"path": text
let Response1 = HTTP.request(
url,
method: 'POST',
headers: {"Accept":"application/json"},
continueOnError: true,
body: HTTP.multipart('form-data',
//{ contentType: 'application/octet-stream', content: FirstDoc.data, name: "file", filename: '"'& FirstDoc.filename & '"' }
//{ name: "file", filename: '"'& FirstDoc.filename & '"', content: FirstDoc.data }
{ content: 'name="file"; filename="' & FirstDoc.filename & '"' }
let SuccessResponse1 = case when Response1.statusCode = 200 then
JSON.deserialize<ResponseType>(Response1.asText())
else default(ResponseType)
end;
let ErrorResponse1 = case when Response1.statusCode != 200 then
JSON.deserialize<ErrorType>(Response1.asText())
else default(ErrorType)
end;
return {
HttpStatusCode : Response1.statusCode,
ErrorMessage : Response1.reasonPhrase,
DetailedErrorMessage : ErrorResponse1.detail,
Headers : Response1.headers,
Result : SuccessResponse1
Postman raw log (working):
POST /api/v1/files/ HTTP/1.1
Authorization: Bearer sk-07b9bd38fe914310a35d0a803a8e9e50
User-Agent: PostmanRuntime/7.51.0
Postman-Token: d068f64e-0684-4bed-91eb-f9708402dce4
Host: localhost:3000
Accept-Encoding: gzip, deflate, br
Connection: keep-alive
Content-Type: multipart/form-data; boundary=--------------------------831347693450459289231793
Content-Length: 293989
----------------------------831347693450459289231793
Content-Disposition: form-data; name="file"; filename="Changes to Production for Shifts.pdf"
<Changes to Production for Shifts.pdf>
----------------------------831347693450459289231793--
HTTP/1.1 200 OK
Date: Mon, 29 Dec 2025 06:30:18 GMT
Content-Type: application/json
Transfer-Encoding: chunked
Vary: Accept-Encoding
x-process-time: 0
Server: Cloudflare
Referrer-Policy: no-referrer
X-Content-Type-Options: nosniff
X-Frame-Options: SAMEORIGIN
X-Permitted-Cross-Domain-Policies: none
X-Robots-Tag: noindex, nofollow
X-XSS-Protection: 1; mode=block
Permissions-Policy: geolocation=(self), midi=(self), sync-xhr=(self), microphone=(self), camera=(self), magnetometer=(self), gyroscope=(self), fullscreen=(self), payment=(self), interest-cohort=()
Content-Encoding: br
{"id":"9aeb3358-2de7-4503-b81e-95542ce55abd","user_id":"a7dbe76a-0ab2-4b67-a23b-c478bcddf082","hash":null,"filename":"Changes to Production for Shifts.pdf","data":{"status":"pending"},"meta":{"name":"Changes to Production for Shifts.pdf","content_type":"application/pdf","size":293750,"data":{}},"created_at":1766989818,"updated_at":1766989818,"status":true,"path":"/app/backend/data/uploads/9aeb3358-2de7-4503-b81e-95542ce55abd_Changes to Production for Shifts.pdf","access_control":null}
Has anyone done this before? How can I get the fields required? Any help is appreciated.
