Portal2 - Define column width
Hi all!
In the old Portal there was a way for a developer to lock the width of columns displayed in a table portlet. Is that option still available somewhere in Portal2 and I am just not finding it or is this no longer possible?
Hi, no longer possible except by rearrange them, and then go in to the setting and press “save column settings” (and the sizeof rows and font a bit furhter down if ajdusted).
Thank you Ola! I found the button you mention after posting this, and it works. I don’t need to specify the exact column widths as long as I can default some columns to be smaller than normal (for instance for a checkbox), and the “copy from portlet” button helps me accomplish that.
