It appeared that two REST API calls in immediate succession fail in the second call: after a POST to create some object (201), a GET some info about the same object (404 instead of 200).
When a User Step is inserted between the steps and the user waits a few seconds, the second step succeeds (200) !
Now the question is how to make a step that waits or sleeps a defined number of seconds before continuing the flow.
There is a sleep function you can run in an assignment step between the requests. The below is from the Flow Connect help but the sleep function exists in Classic as well. Not sure why it’s not documented there ![]()
Signature: sleep(minMilliseconds: number, maxMilliseconds: number) → number
Pauses script execution for a randomly chosen number of milliseconds between minMillisecondsand maxMilliseconds.
sleep(10000, 10000) // will return 10000 and pause the execution for 1 sec
Great, hope it solved your issue ![]()
