Default rows in a data grid
In flow 6.14, where is the grid’s number of rows to initially display stored? And can we change the default number of rows for the users?
Hi, there is a “defaultGridPageSize” setting that can be set in the web client’s web config. see:
Web client - Flow Help for more info.
You can also see and modify it for your user per each grid using F12 in the browser:
Neat idea, Ola, but how do I know which one is the current grid? I have a dozen grids in that list.
We should probably make that easier to figure out, but for now I think the solution would be to either change it to something unique in the drop down and see which one got updated under the local storage. Or if you have a hunch, you could change it to 46 or something that is not possible to select from the UI and see if it was the correct grid.
