Export flow
Is it possible to export a flow from the web portal? I don’t see an option to do that anywhere.
Only by using the share feature
Thanks for the reply, but that isn’t really what I want to do. I have a flow with a component flow “inside” it (like an Included flow in Flow Classic). When the user exits from the component flow I want it to go to the step in the flow where the “parent” flow entered that component flow. What is happening instead is when the user exits the component flow it exits the application entirely, it doesn’t go to the point in the “parent” flow where the component flow was “entered”.
That isn’t the way it worked in Flow Classic.
It should return to the parent flow right after the component’s exit ring. Or do you mean that the user quits the application while inside the component?
Yes if the user quits the application while inside the component flow it doesn’t go to the point in the parent flow directly after where the component flow was called. It also exits the parent flow.
