Exersice 4
Hi, I get a triangle with an exclamation mark in it when I connect my workflow to the menu. I was unsure if I have done anything wrong that will obstruct anything in the upcoming exercises?
Hi, If you hover over the triangle, does it say something? I suspect that you haven’t published your workflow. Should probably out something about that in the material, its a common mistake.
yes ola you are right. Even I did this at a time, this even sometimes result into the lens icons right to every roles. That is also a situation most times when we forgot to publish the workflow.
